Aileron Balance tool
Posted: Fri Mar 29, 2019 8:59 pm
				Our ailerons are balanced from the factory.  There are heavy weights  bolted to the outboard forward edge of the aileron.   For the "V" strut C-120 and C-140's they weigh about 3.5 lbs.  (quite a bit!, but then the weights are very close to the hinge line)
The 140A have weights about 1/2 that weight.
NOTE: The elevators are not balanced.
From the old website I've located this tool drawing for performing aileron balance checks. It's not terribly scientific once you've done a few.
