Mistaken Identity?
Moderators: 6643, 6183, V529
Aircraft Type: C120
Mistaken Identity?
Post by 6863 »
A friend of mine in MN went to a flyin in Osceola last week and took this picture of what he said is a 170. I told him it is not a 170 but is instead a 140. He then sent me the faa.gov registration info which sure enough says it is a 170. I'm curious.
https://registry.faa.gov/AircraftInquir ... rTxt=4098V
John Kliewer
Re: Mistaken Identity?
The original 170 is very similar to the 140. 2 more cylinders and 2 more seats...
6298
Aircraft Type: Cessna 140
Post by 6298 »
Much bigger elevator. Looks like the rudder is, too. Can’t see the windshield, but the 170’s had a split windshield..
At a distance, the entry step is a clue, 'though with rag wings they can surely appear similar to a 140, especially from a distance. Just from memory, it seems that in addition to stretching the fuselage, rib(s) were added to the wings and an additional fuel tank was added to one wing(?). ...also, maybe came initally with the C-145 that became the 0-300? I believe they used the 140 gear (sans the step holes) which was good testimony to the toughness of the gear. Haven't seen one in several years. Beautiful airplane...but, then, aren't they all? Mac
simonlowther
Aircraft Type: C120
Occupation-Interests: Airline pilot Airbus 320
Post by simonlowther »
Another clue might be the horns on the tail feathers, correct me if I am wrong but 140 is sans horns.
Si
Simon Lowther
Cessna 120 (11102)
Occupation-Interests: Retired
Post by 4004 »
Yes! Good catch - some things are so easily missed. Flew one in the late 40/50s - just an overgrown 140!
6863
Aircraft Type: C120
Post by 6863 »
The entry step and elevator horn have me convinced. The two piece wing struts thew me. The tail feathers may be larger but their proximity to the camera vs the other end of the airplane make them look even larger so I did not let that influence my perception.
Thanks guys for setting me straight.
John Kliewer
meloosifah
Post by meloosifah »
Definitely an early 170 - as others mentioned: larger control surfaces on tail, step, extended fuselage, double struts. Nice plane!
Post by V529 »
No skylights.............
Users browsing this forum: No registered users and 8 guests
