Am I overthinking this? CFI's?
Posted: Wed Dec 16, 2020 8:43 am
Looking for an airplane to do a bit of teaching in. Looking at metal wings due rag wing recover possibility. Have looked at two, rejected pre buy on one, on cusp of doing pre buy on another. I do have an old port a port full t hanger secured.
Current subject had wings done in 1976, and had a complete equipment list along with new W and B record done at that time. Showed a weight of 959-ish. STC used says weight gain of 12 pounds. Only additional changes since then were shoulder harneses (2 pounds) spin on oil filter (3 pounds), 0200 install (3 pounds), VG's (.5 pounds maybe?), some fancy sun visors (2 pounds) and a radio in and out. As part of my intial look, we had it weighed. It now weighs 1017 pounds, no fuel, full oil. Somehow, with nothing obviously done, it's gained 60 pounds since the last W and B. Low hanging fruit to add another gallon or two is an odyssey battery, replace heavy carpeting/door panels/head liner (which is still presenting well) remove hat shelf, remove wheel pants brackets, remove unnecessary venturi. All of that may be 15 pounds and will cost, what, $1200? I know abourt Skytec and BC alterntors, but that is more then I want to spend to save 8 pounds until they fail. Mike Busch will be proud.
The wing has inspection ports .
As it sit's can get a max 200 pound student in flying kit, ditto me, and twelve gallon's useable in and be legal. I'll be at or near gross most of the time, north georgia, DA 3500 ish in the summer, no obstacles, 3000 feet of grass or 5000 on concrete.
Airplane presents well, owner is a straight up guy, well thought of by his A/I, has 5 other airplanes in his hanger, (s) etc. STC's/ mods: 0-200/350 hours on reputable rebuild, spin on oil filter, VG's, Clevelands, Scott 3200, fancy sun visors, strobe, leading edge landing lights, shoulder harneses, electric T and B. Everything works. Needs a VSI, and airspeed looked wacky on test flight (way high at cruise, like up around 120 at 2400 RPM, gusty day). Airframe logs missing pre 1960, with note of carry over TT. Engine logs on 0200 back to rebuild. Owner had nice binder of airplane history. Airplane is in ballpark price wise, owner is firm bearing an airworthiness issue during pre buy
I like the look, I like the mods. Seems to fly well.
So this begs the question: Am I getting two wrapped around the axel about weight and performance at max gross, and limiting my student weight? Or, should I discount the need to recover the wings at some point, and expand look?
Scott
Scott
