Engine Failure in flight
Posted: Sun Sep 26, 2021 6:01 pm
Ladies and Gentlemen, fellow 120/140 owners:
I just experienced my first engine failure after 50+ years of safe flying. I was enjoying clean and cool air in the Florida panhandle when I suddenly experienced engine vibrations? Having been a Flight Instructor for years, and what I teach students, I first applied Carburetor Heat, although it was warm and conditions didn't exist in cruise flight that carb ice might occur. After application of carb heat with no change in the airplane shaking violently, I turned to the nearest airport, 18FD, Skypark. No ATC was involved and the weather was CAVU so there was no need to call ATC to declare an emergency or squawk 7700 since I was out of controlled airspace.
Completing my engine scan, fuel tank checks, carb heat, and oil temperature and oil pressure, all normal, I maintained power and altitude as best I could while reducing airspeed to best performance. I was able to maintain 1500 agl until the engine finally quit simultaneously with extreme airplane vibrations. I was about to shut down the engine to stop the vibrations when it quit completely. I then realized I couldn't reach my intended airport of choice and looked for a suitable place to land. Scanning the area while maintaining best glide speed, I spotted 3 possibilities but elected to land on a hayfield, which, by the way was best for wind condition although we seldom have bad winds in our area of Florida.
I maintained about 60 mph until I knew I had made the landing area, shut off my fuel and all switches before touching down a hayfield about 2500 feet in length. After I rolled to a stop, I exited the airplane to inspect for physical damage and noted some oil on my windshield. I then opened the right cowl to discover a large hole in the engine case, later to be determined the #2 engine rod that had failed. Upon checking further i found that I still had 4 quarts of oil.
Thank goodness, God was my copilot through this ordeal.
Good news: I rolled to a stop near a main road, pathway to that road and recognized that I was just south 1/4 mile from friends. Shortly after I completed my post emergency landing, aircraft evaluation, and situation, 2 guys in a pickup drove by coming from a nearby wooded area. After I answered their question, "how did you get here", I learned that they are bee keepers and had just come out of the woods. They offered help in the form of transportation, which I accepted, and was dropped off @18FD, Skypark airpark, North of Baker, Florida.
All in all, no damage to pilot or airplane less the engine-!
