Help
Posted: Wed May 02, 2018 7:07 pm
by 8170
When I login to the page then change pages by clicking a link on the page it wants me to log in again. I never had this issue before. Suggestions?
Joe
Re: Help
Posted: Wed May 02, 2018 8:46 pm
by Rob Swanland
Hi Joe... thanks for alerting me to a problem here. Can you give me a little more information so that I can replicate the problem? What page were you looking at when you experienced this problem... specifically what link did you click on? Thanks
Re: Help
Posted: Fri May 04, 2018 6:47 am
by 6183
I think was able to replicate what Joe is talking about. Basically if an individual goes to the top of forum page and selects forum (in the red bar above) to try to navigate to another forum say from the pilots lounge to technical you're required to sign back in. However, if you go to the "jump to" section below the forum subject box you can navigate between discussions and not have to sign back in.
Re: Help
Posted: Fri May 04, 2018 5:39 pm
by 8170
Basically if I log in then go to a board im ok. As long as I hit the back button it will stay logged in. If I navigate anywhere elsesay from the main page then click the forum button in the banner it tells me I need to log in
Re: Help
Posted: Fri May 04, 2018 5:48 pm
by Rob Swanland
Joe, thanks for the details. I am aware of the problem as you describe it - I haven't figured out the cause of this behavior just yet, but I am working on it. To avoid getting logged out, but to still get back to the main forum view, try clicking on the "Board index" link - this is a blue link in the light blue bar. I will keep you posted on the fix to the red menu bar problem... Rob
Re: Help
Posted: Fri May 04, 2018 5:57 pm
by 8170
No worries Rob. I am not complaining at all I just wanted to make you aware. Thanks again for all of your hard work.
