C-140 CFI NW Ohio
Posted: Wed Oct 17, 2018 10:32 am
by 8342
Hi All,
I need to find a CFI in the Northwest Ohio/ Southeast MI area.
Insurance requires 10 hours in make and model. Cessna 140.
I purchased an out of Annual C-140 that is located on a private strip and need to get it moved to a location so that the Annual can be done.
Once the Annual is done will I need 5 hours dual for insurance purposes.
If you know of someone interested you can post it here or PM me.
Re: C-140 CFI NW Ohio
Posted: Wed Oct 17, 2018 10:54 am
8342 wrote: ↑Wed Oct 17, 2018 10:32 am
I ... need to get it moved to a location so that the Annual can be done.
In order to move it legally (without taking it apart) you'll need a ferry permit. To get a ferry permit you'll need an IA to sign it off as airworthy. It might be easier and cheaper to have it annualed where it is.
Posted: Wed Oct 17, 2018 6:01 pm
by 8342
Thanks for the information.
I am and A&P and have already made arrangements to get a Special Flight Permit.
Posted: Thu Oct 18, 2018 8:29 am
by 6898
looks like there are 5 cfi's in Ohio and 5 in Mich. Do you have a members Assc. directory? if not 815 695 9970 CST M-F Good luck Jeff
Posted: Thu Oct 18, 2018 5:58 pm
by 8342
Thanks Jeff, I may have found someone but will use your info for a backup.
Thanks for all,
Posted: Wed Oct 24, 2018 7:59 pm
I've been out of town for the past week and just saw this. We have a couple of pretty active members in NW Ohio. Did you find someone?
Posted: Fri Oct 26, 2018 5:16 am
by 8342
529 wrote: ↑Wed Oct 24, 2018 7:59 pm
Yes, thank you.
Posted: Thu Nov 15, 2018 6:01 pm
by 8342
6643 wrote: ↑Wed Oct 17, 2018 10:54 am
For future reference, an IA is not need to get a Special Flight Permit (Ferry Permit).
Go to the FAA website and download Form 8130-6.
Complete required sections.
Fax it to the FSDO who has jurisdiction of the departure airport.
If they like it, they will fax or email your approved permit along with a list of restrictions.
These include a sign off by an A&P in the maintenance logbook certifying AD compliance and safe for flight.
Posted: Fri Nov 16, 2018 11:27 am
8342 wrote: ↑Thu Nov 15, 2018 6:01 pm
You are correct. However, unless you can find an A&P who is familiar with that particular aircraft, I'd expect whoever is signing it off would want to do the equivalent of a 100 hour (same scope as an annual) inspection before signing it off. Might be easier to get an A&P than an IA, though.
