Login, Login, Login . . . . . Login ????
Posted: Fri May 04, 2018 8:45 pm
by 5099
Why do I have to keep Logging In even after I check the Keep Me Logged In box?????
Steve
Re: Login, Login, Login . . . . . Login ????
Posted: Fri May 04, 2018 8:58 pm
We are aware of the problem and are working on it...
Meanwhile, please bear with us. It's been a long row to hoe...
Posted: Fri May 04, 2018 9:10 pm
by 5099
That's Cool, I understand. I just hope I don't have to Login to go to the bathroom. I might not make . . . Never mind, Too Late.
Posted: Fri May 04, 2018 9:56 pm
You should be able to go to the bathroom without logging in, but if you were logged in before, you'll probably have to log in again when you get back.
Posted: Fri May 04, 2018 9:58 pm
by Rob Swanland
Steve, sorry for the inconvenience! Like John mentioned we are working on the issue. The good news is that you really don't need to touch the red menu selections in order to use the forum (and to remain logged in). Everything you can do by clicking on the red menu selections can be accessed by another means - check out the blue links above and below the forum area. The purpose of the red menu bar is to facilitate some new features, yet to come. Hope this helps your incontinence fears.
Posted: Sat May 05, 2018 12:34 pm
by Rob Swanland
ok, I think this problem is fixed now. Please click on "Delete all board cookies" at the bottom of this windows and refresh your browser window. Let me know if this fixes the problem for you.
Posted: Sat May 05, 2018 5:08 pm
I've tried everything I could think of and stayed logged in, so I'm thinking it's fixed.
Thanks Rob!
