LH wing tip damage... C-140
Re: LH wing tip damage... C-140
Look at it this way; the regs tell you what you cannot do. If what you're wanting to do does not conflict with the things you cannot do, and you're confident the way you are doing it is suitable to the repair and "acceptable to the administrator" then you're good to go.
