Leaf spring p/n
8296
Aircraft Type: 1946 C-120
Occupation-Interests: Retired airframe structures engineer for the USAF
Re: Leaf spring p/n
Post by 8296 »
5115 wrote: ↑Mon Sep 03, 2018 7:14 pm I ordered 05-07055 for my 1946 sn:9168 and it is the good match for the Scott 3200. As per 6597 second picture we can see that Scott table is parallel to ground, which is the best setup.
Martin, I have a 1946 low serial number (9290) C-120 with the now standard offset blocks on the landing gear. I would assume that your C-140 is same. Could you please confirm. I need to replace my tail springs when I return my aircraft to airworthy status. I too have the Scott 3200 tailwheel. I want to get rid of the tail shake for good and no the attachment bracket is solid and neither the bracket or mounting rivet field have any cracks. I ask this question because as I have come to learn from reading many articles on this problem the vertical pivot axis of the tailwheel must be pointed slightly forward, or so I seem to recall.
