C140 Flap Lever Assembly
stephendriskell
Post by stephendriskell »
I’m looking for figure 15 reference 44 part# 0411322. It houses the detent that the flap lever uses to hold the flaps in position when deployed.
Mine has completely worn out and is in need of replacement. So I’m looking to find and purchase, long shot, or manufacture one using the old part as reference.
Looking for advice for either. Here is pic of worn out part.
Name: Steve A H
Aircraft Type: 1950 C140A
Occupation-Interests: Retired
Re: C140 Flap Lever Assembly
Post by 8424 »
Hi Stephen, This is Stephen who goes by Steve A H on this forum!
In my parts manual your part is 15-33...part number 0411322, Cover Assembly - Flap Control - Left - (Serial 8001 - 10069)
Here's you long shot!
I have one, and will send you a PM.
Steve A H
8424
Name: Steve A H
Post by 8424 »
Stephen,
Did you locate an assembly?
Mine is still available. Let me know if you need it.
Steve A H
Flap Control Assembly 3a.jpg (25.94 KiB) Viewed 3947 times
Flap Control Assembly 1a.jpg (24.85 KiB) Viewed 3947 times
atypicalguy
Post by atypicalguy »
Not sure how this turned out but I could use that part if it is for the twist grip handle.
Karl
8424
Name: Steve A H
Post by 8424 »
Hi Carl!
The gentleman looking for this part never responded to the above post or to PM's that I sent him, so it is available to you if you are interested.
I also have the right side of the assembly, shown below (figure 15-12 0411323, cover assembly - flap control - right) , but it has a latch assembly attached at the front for what appears to be the push button lever operation. It appears a part has been removed from the holes in the lower front of the piece.
These parts are in the exploded view of the twist handle unit in the parts manual, but I have no experience with this type of flap handle. Just happened to get these in a box full of parts I purchased a while ago.
I've sent you a PM.
Steve A H
Flap control assembly right 1a.JPG (24.43 KiB) Viewed 3761 times
[attachment=0]Flap Control Assembly Right 2a.JPG[/attachment
Flap Control Assembly Right 2a.JPG (21.37 KiB) Viewed 3761 times
