Hello,
I will install Alcor dual EGT with new Alcor EGT probes type K, PN 86255.
Probes came packed with STC No SA 522 SW
I am aware about SB M89-18 that Supersedes M76-19 Rev. 1
My mechanic has no previous experience to select the two cylinders for the installation, as there are very few 140s here.
Thanks for experience / ideas about this subject,
Have a nice day !
Leanest cylinders for dual EGT install.
5469
- Name: Horacio Berardone
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
- Name: Randy Thompson
Re: Leanest cylinders for dual EGT install.
#2 is the hottest cylinder. The air flow tends to go over to #1. Not sure about the exhaust gas temperature.
5469
Thank you, Randy !
Best regards
Best regards
