crankcase breather elbow
Occupation-Interests: retired airline pilot
Post by 7414 »
It's time to get my 140 out of hibernation here in upstate New York.
This time I would like to use the Mike Bush method by pre lubricating the cylinders and crankcase with an oily mist.
To have better access to the crankcase can I simply unscrew the original breather elbow without getting myself into technical difficulties ?
Thank you.
Re: crankcase breather elbow
I'm not sure exactly what you're trying to do, but, could you do it through the elbow just as easily as through the hole left when you take it off?
7414
Post by 7414 »
The idea is to cover the moving parts inside with a film of oil before first start up by blowing an atomized oily mist into the crank case.
Doing so via the 90` elbow would make it somewhat less effective I suppose.
Even without the elbow, the path is pretty convoluted.
If you're blowing something in, something else needs a way to get out. You can open the oil fill cap, but if the oil level covers the fill pipe, oil is going to come out instead of air...
Anything like these useful? My 0-200, don't know the story on the 85's
0-200 plugs.jpg (76.86 KiB) Viewed 2096 times
Those are your main oil galleries.
