McCauley Propeller question
Aircraft Type: 140A/C90-14F
Re: McCauley Propeller question
Post by 8413 »
John,
I will see if I can find someone with an optical tach. Compressions at annual in October were 70,64,74,75. There is a note in the logs back around 2001 at 10hrs after they installed the new Millenium cylinders indicating 2050 static rpm, so it seems not much has changed.
Josh
