Steve Rose
REAL Push Rod Tube STC
- 6339
- Name: Steve Rose
- Aircraft Type: '48 140
- Occupation-Interests: Retired Navy Maintainer
Re: REAL Push Rod Tube STC
Michael; Sorry to be late responding, I just saw your post. I also have a late serial number 48 with the C-90 and I had your symptoms when I first got my plane. Sure enough the motor had been top ended and "improved" with drilled rocker arms. Going back to the late-model intake rockers cured my oil in the intake/carb box. So...I would say that Randy has the measure of it
Steve Rose
Steve Rose
Well now that explains a few things on my bird......
- 6-16-09 006.jpg (192.25 KiB) Viewed 3733 times
4945
- Name: Gary
- Occupation-Interests: Retired Congressional Staff, Navy Reserve Retiree, Former P-3 Flight Engineer, Former aerospace technician
I was about to send my rocker arms in to Aicraft Specialties and noticed I have the same issue. All the rocker arms are drilled. At around $500 each, it's too bad the hole can't just be plugged.
Gary
Gary
Gary,
I contacted Todd at Smokin' Rivets and he got me some exchanged overhauled rockers cheap, make sure you check the pushrod lengths on valve lash for overhauled rockers.
Todd Littfin
www.srairparts.com
smokinrivetairparts@gmail.com
715-450-3689
Chippewa Valley Regional Airport (KEAU)
Todd Littfin
www.srairparts.com
715-450-3689
phil123
- Aircraft Type: C140-O200
I have drilled intake rockers and don't see a problem with oil pooling in the airbox? Might be a int. guide wear issue but that's just a guess.
