Seat Belt Brackets
Aircraft Type: C-140 (sold)
Re: Seat Belt Brackets
Post by 8342 »
Check Page Figure 15 it shows both the center and the outboard brackets.
Center bracket part number is 0425132, unless it changed when it went to steel.
Outboard right bracket is 0411528.
Outboard left bracket is 0411528-1.
Double check numbers I have not had my coffee yet.
According to my IPC part number 0411667 Figure 1-22 is listed as a bushing.
Cheers,
Aircraft Type: 1946 C-120
Occupation-Interests: Retired airframe structures engineer for the USAF
Post by 8296 »
You are right. I was so locked into David Lowe's installation instructions that came with the STC that I overlooked the detail description in the parts list. I will have to contact (unless he is reading this) David and tell him he has the wrong part number (in at least as my STC attachment) in parentheses beside the words "seat belt bracket" in the installation instructions, line item 5.
Again, can you still buy these parts and from Yingling? I assume you can. And again, a picture, if anyway can come up with one of this installation on a C-120, would be helpful.
George
If you bought the STC from David, I'm sure he wouldn't mind answering your questions.
It is my recollection that David just used the same brackets as were used on the outsides of each belt, although maybe it was the left on the right side and vice-versa. I could be wrong, though...
