Firewall crack repair
8475
- Name: Dave Sprinkle
I noted that my firewall was cracking at the starter cable pass-through.
- N76415 firewall cracks.jpg (62.52 KiB) Viewed 4909 times
8475
Re: Firewall crack repair
I cut out the cracked section.
- N76415 firewall cracks removed.jpg (66.95 KiB) Viewed 4908 times
8475
I added a patch to cover the damaged section. Also added a couple of spherical "eyeball" fittings to support the penetrations of the other cables (mixture, throttle, oil temp, tach).
- N76415 firewall patch and cable fittings.jpg (79.64 KiB) Viewed 4907 times
8475
Here's a close-up of the spherical cable fittings These are made by DoubleTee. I had these custom drilled to support two pass-throughs each. I highly recommend these.
https://www.firewallfittings.com/product/ttp-s-custom/
- N76415 firewall cable fittings.jpg (56.14 KiB) Viewed 4907 times
8475
Here's a picture of the finished installation. Really pleased with how this turned out.
- N76415 firewall cracks patched.jpg (116.55 KiB) Viewed 4907 times
