A&P says we need to replace the 2 rudder cable pulleys (left & right) that are found under the access panels just aft of the fuel selector. The Parts Manual shows these as part number A-130, however the pulleys currently installed are labeled Formica A-210-3.
I'm not having any luck finding these... anyone have a source?
Ed Loskill
8065354082
Need Rudder Cable Pulleys
eagledriver
- Name: Ed
tonycondon
- Name: Tony
Re: Need Rudder Cable Pulleys
Spruce says that the MCS378-3 replaces the A-130 Pulley
https://www.aircraftspruce.com/catalog/ ... ulleys.php
N2395N
chriscrewdson
- Name: Chris Crewdson
- Aircraft Type: Cessna 120
McFarlane has all of these as well for better prices.
The MCS378-3 is the replacement for the A-130: https://www.mcfarlaneaviation.com/products/MCS378-3/
A chart with all the PMA numbers: https://media.mcfarlaneaviation.com/doc ... edures.pdf
The full kit: https://www.mcfarlaneaviation.com/products/PULL-KT-01/
