How to put Cessna 140 85hp on floats
alan
Post by alan »
Hello everyone,
I was hoping to talk to a few people that have done this or know how to. If you have any floats for sale as well or rigging.
From what I see edo 1320's or 1400's would be best. I think the 1650's will work with 85 hp but not very well.
Will probably have to make my own parts for the 140 to attach the floats and I see you need the V brace for better support.
I found one person that used 1400's so will probably aim for those in case the 1320's are too light. Anyone confirm the 1650's would be too heavy?
Re: How to put Cessna 140 85hp on floats
Post by 6183 »
If you haven’t already done so, take a look at the Type Certificate Data Sheet for your aircraft, A-768. Univair has a good library, here’s the link,https://dyzz9obi78pm5.cloudfront.net/ap ... rev-35.pdf. TCDS shows only Edo 92-1400’s and 88-1650 floats are approved for installation. Additionally, take a look at these past posts concerning float installation on the Cessna 140/120.
https://www.cessna120140.com/Forum2018/ ... f=7&t=1753
https://www.cessna120140.com/Forum2018/ ... f=7&t=1598
Not saying that 1320’s can not be used, but you’ll have to have an STC to do so.
Here some more info:
https://www.kenmoreairharbor.com/upload ... design.pdf
alan
Post by alan »
6183 wrote: Sun Mar 09, 2025 2:03 pm If you haven’t already done so, take a look at the Type Certificate Data Sheet for your aircraft, A-768. Univair has a good library, here’s the link,https://dyzz9obi78pm5.cloudfront.net/ap ... rev-35.pdf. TCDS shows only Edo 92-1400’s and 88-1650 floats are approved for installation. Additionally, take a look at these past posts concerning float installation on the Cessna 140/120.
Thank you, I have read those two threads a dozen times already :) It looks like the 1400's are the ideal floats for this airplane and you can 337 to use a 85 hp instead of a 90 hp or greater. Which would be good for me. Hoping someone with the floats or riggings or etc see's this post.
