More exhaust questions
Re: More exhaust questions
Post by a64pilot »
2066 wrote: ↑Tue Dec 29, 2020 2:46 pm
"...cut and reweld for a perfect fit".
Yep, I've had to do that a few times over the years (...changed pipes a few times in 36 years owning -- they're never the same distance apart). Anything you can do to have a firm fit, but without being "sprung" will help prevent cracking. your installation looks good!! RE the stud, I have had that one break, right at the drilled hole, and I replaced it with an undrilled that's a bit longer. Mac
I’ve got longer studs, and was going to do the double nut trick to remove existing stud, but was a advised that had about zero chance of working. Not knowing what else to do to remove the stud I didn’t, fearing a broken off short stud.
Plus this airplane is now 77 yrs old, assumption is the engine may be too, and it’s made it all those years with a drilled stud. At some point in it’s life it’s likely it had a brace mounted?
Post by a64pilot »
If this works, it will show the inside of a VW heat exchanger
https://images.app.goo.gl/wXowkjsSyL55wrU66
That’s the way to get heat, anything would help even springs I’m sure
a64pilot wrote: ↑Tue Dec 29, 2020 3:08 pm
I was a bit antsy about removing the studs, too, but my IA is an old Marine oil burner mechanic and had them removed before I could tell him that it couldn't be done :shock: . Mac
tomford
Post by tomford »
Is anyone repairing or re making the original style straight pipe shrouds?
Tom
tomford wrote: ↑Sun Sep 10, 2023 1:39 pm Is anyone repairing or re making the original style straight pipe shrouds?
Tom
It's been awhile...but, last time I checked with ACORN Welding they would "repair" (rebuild yours) the shrouds. As best recalled, the price quoted was close to $1,000 each. They are repairable, of course, and the curves and bends can be a bit tedious to work but I've seen a few over the years made serviceable by owners/mechanics that looked very good. Don't forget to take a gander at Ebay occasionally -- they do show up there with some looking good, some not so.
Mac
Tom
I've got a pretty decent used set if you can't get yours repaired.........reasonably
atypicalguy
Post by atypicalguy »
Do you still have those straight pipe shrouds? Bottom of my left one just cracked off and I figure I might as well replace them both.
Karl
310.614.2568
V529 wrote: ↑Wed Sep 13, 2023 11:01 am
Tom
atypicalguy
6643 wrote: ↑Tue Dec 29, 2020 2:58 pm
a64pilot wrote: ↑Sat Dec 19, 2020 9:47 amIf you find a way to increase the surface area of the pipe under the muff, that should increase heat output, but wouldn’t be easy I don’t think.
Just noticed this. Alons and Mooney M10s had a pair of springs (Home depot screen door springs) wrapped barber pole style around the pipe.
This is a good idea for replacing the spacers if they fit.
