ID plate
- dcannon
- Name: Dan Cannon
- Aircraft Type: 1946 C120
Re: ID plate
Door post or glare shield. As they are prominent I am guessing yours might be missing. I went through the process of a replacement data plate. Cost me a few months of waiting and almost $3000.
Re: ID plate
Thanks for your quick reply.
Re: ID plate
Can you say which door post upper or lower or where on the glare shield, some one in the past has covered all those areas with glued on Vinal.
- Name: Ken Kelley
- Aircraft Type: 120
Re: ID plate
The data plate is located on the lower left door post or on the left upper surface of the glareshield.
