primary flight display
jimmy
has anyone installed a AV30 primary flight display in a C120-140,if so where did you put it on the panel.
Re: primary flight display
Replaced my turn and bank which was in the left-most 3 and 1/8" hole pretty much right above the yoke.
jeffmunday
- Name: Jeff Munday
- Aircraft Type: C120 - N508JM
- Occupation-Interests: A&P IA CFI/MEI
How do you like it so far? Did you go with one or two(elimating the 'vacuum' system? I was told they are kind of dim in certain situations.
