Window hinge pins
atypicalguy
Window hinge pins
Post by atypicalguy »
For some weird reason my window hinge pin in front was halfway out and the rear one was missing after the most recent annual. Maybe someone was trying to steal my Aera 660 while it was parked outside. Anyway does anyone know if all those cessna hinge pins are the same part number? I figured I would just put two new ones in.
Karl
Re: Window hinge pins
I think I just went to the hobby store and found the right size music wire....
I'm not near the plane, but, isn't it just regular NAS hinge pin material?
atypicalguy
I had no idea such a thing as pin stock existed, but I still need to find a place to get some. Maybe the shop across the lot has some.
Aircraft Type: 48 140 C90
Post by 6898 »
McMaster Carr has them, in stainless too
Don't use a stainless pin in an aluminum hinge!
MS20253 Hinge Pin.jpg (52.61 KiB) Viewed 157 times
atypicalguy
Why would low corrosion stainless not work in aluminum? I was thinking 304?
atypicalguy
Oh I guess the one I found at Spruce is passivated also:
https://www.aircraftspruce.com/catalog/ ... 9000-3.php
atypicalguy wrote: Sat Sep 12, 2026 11:37 pm Why would low corrosion stainless not work in aluminum? I was thinking 304?
It's hard to explain in one paragraph, but metals have a property called "nobility" measured on a chart of "galvanic corrosion." Metals on one end of the chart (magnesium, for example) are prone to corrosion and on the other (stainless steel) are not. The issue is, corrosion is promoted based on the distance on the chart between the two metals in contact. So, magnesium castings with magnesium bolts would not promote corrosion, but aluminum in contact with stainless steel would. The aluminum corrodes at the expense of the stainless.
So, if your intent is to protect the pin, stainless is a good choice, but if it is to protect the hinge, cad plated is better. (Cadmium and aluminum are very close on the scale.)
