Fuel selector valve
- Name: Lynn A
- Aircraft Type: C-140A
Re: Fuel selector valve
My selector value finally went south on my Cessna 140A, and I was able to purchase an overhauled unit from Dallas Air Salvage in Lancaster, Texas for $450.00. It's a left, both, right and off. Lucky said it's an imperial mfg. unit. The front end is beefed up as they are known to crack. The Cessna part number is 0413020-3 and the O-ring inside when you can now replace is a MS29513-011. if you need one, call him and he will hook you up.
- 8413
- Name: Josh C
- Aircraft Type: 140A/C90-14F
Thanks!4457 wrote: ↑Tue Sep 29, 2026 5:49 pm My selector value finally went south on my Cessna 140A, and I was able to purchase an overhauled unit from Dallas Air Salvage in Lancaster, Texas for $450.00. It's a left, both, right and off. Lucky said it's an imperial mfg. unit. The front end is beefed up as they are known to crack. The Cessna part number is 0413020-3 and the O-ring inside when you can now replace is a MS29513-011. if you need one, call him and he will hook you up.
4457
- Name: Lynn A
Lucky can be reached Tue-Fri at Dallas Air Salvage at 972.227.1111 I'm sure he would have the other Cessna fuel selector valve.
Lynn
Lynn
