Approved 337 for solid Grove axles
Post by 8170 »
Got this from a friend and I am using the data to get a field approval. I will post my approved 337 when it comes back from the FAA
C140 Grove axle Approved 337.pdf
(214.77 KiB) Downloaded 793 times
Re: Approved 337 for solid Grove axles
Post by 8170 »
Could someone add this to the library please?
A copy of the letter from the Wichita ACO would be helpful...
Post by 8170 »
I don't have it. This is all I was given. I submitted my own 337 for field approval if it comes back approved I will post it as well.
Post by 8170 »
Got an email from My inspector at the FSDO indicating that he would approve my 337 using the one posted as data. I will post my approved 337 as soon as I get it back. Now I'm off to order my new axles. :)
Post by 8170 »
If you have 4 1/4 inch bolts holding your axles on make sure you ask for the 5016-2 axles. If you order the 5016 axles from Spruce they will have 2-3/8 holes and 2 5/16 holes. Ask me how I know :(
Post by 8170 »
Came home from a business trip to a pleasant surprise. 2 approved 337s. 1 for solid Grove axles and one for 8.50x6 tundra tires. I will post as soon as I get them scanned to PDF. I know what I'm doing next weekend 😁😁😁
Post by 8170 »
I have them scanned to PDF I just need someone to upload them to the forum. Help please. Thanks.
Post by 8170 »
Approved 337s are posted on my thread for the 8.50 tires
