AILERON CONTROL PULLEY -- F-140
Is there a superseded number for this "little" guide pulley that's located center & just aft of the rear spar carry-through? The parts book calls for "F-140". I could probably be OK with a new bushing & bolt...but, in searching for "just" a new bushing (0411783) I'm shocked at prices. (Yep, when we start doing "little" jobs like installing a GPS antenna, we get a case of the might-as-well's & I can see that I might as well replace that pulley while we're there ;-)). Thanks for any leads. Mac
Re: AILERON CONTROL PULLEY -- F-140
The attachment IMG_0516.JPG is no longer available
2066 wrote: Tue May 29, 2018 6:03 pm Is there a superseded number for this "little" guide pulley that's located center & just aft of the rear spar carry-through? The parts book calls for "F-140" (@ #8). I could probably be OK with a new bushing & bolt...but, in searching for "just" a new bushing (0411783) I'm shocked at prices. (Yep, when we start doing "little" jobs like installing a GPS antenna, we get a case of the might-as-well's & I can see that I might as well replace that pulley while we're there ;-)). Thanks for any leads. Mac
Update: S394 is the current # and is a "nylon" pulley -- used on several Cessnas as well as ours. The Pulley is cheap ($7.12)...the bushing($31.72), not so much. Mac
Cessna has always been very proud of their steel bushings. Check out the ones in the trim screw horn.
I may have a line on the original pulley, NOS, for very cheap, if you're interested.
Post by 8170 »
Glad I have a lathe :)
6643 wrote: Wed May 30, 2018 12:10 pm Cessna has always been very proud of their steel bushings. Check out the ones in the trim screw horn.
Thanks, John -- I may be. I've already ordered the "new & improved" pulley from McFarlane + a new bushing, so I'll see how that looks. My IA sez that my pulley is OK -- just need the bushing &, of course, a new bolt. If any doubt remaining, I'll holler. The clearance twixt the cable and the other pulley brackets is really close up there, as you know -- I recall having seen a case where the cable had practically sawed through a bracket :o . Mac
"F" is for "Formica"
If anyone needs one, shoot me a PM. New surplus, no certs.
second photo...
Post by 8170 »
How much? I wouldn't mind aspare or two
Re: "F" is for "Formica"
8170 wrote: Sat Jun 02, 2018 11:29 am How much? I wouldn't mind aspare or two
6643 wrote: Fri Jun 01, 2018 1:02 pm If anyone needs one, shoot me a PM. New surplus, no certs.
How many are we talking about? Send me a PM and we'll discuss it.
OK, I have in hand 58 of these babies. They're NOS, surplus. I have a friend who spends his waking hours pouring through aviation auctions and close outs. He sent them to me for next to zip. (He has 1000 of them).
I don't want to turn this thread into a commercial venture, but if you need one (there is only one used, on the rear of the carry through spar, supporting the aileron carry through cable) I'll be glad to send it along for not much more than the postage. Drop me a Private message.
