leaking fuel strainer valve
Post by 8475 »
The drain valve on the bottom of my fuel strainer is dripping fuel. Where I can source a replacement? Thanks.
Re: leaking fuel strainer valve
I'm pretty sure you need a Curtis CCA-1550. The seal is not an o-ring and not legally replaceable.
6298
Aircraft Type: Cessna 140
Post by 6298 »
If that is the one you have, here is a link.
https://www.aircraftspruce.com/catalog/ ... ickdv4.php
