Scott 3200 cracked fork
Re: Scott 3200 cracked fork
When it was Scott, that steering arm was on some of the 3450 series heavy duty wheels. They were used on things like the Cessna 185. I know some folks put them on the 3200 series assemblies. Not sure that was completely Kosher...
What does ABW call that assembly?
8455
Aircraft Type: C140 / O-290
Post by 8455 »
The entire tailwheel assembly is part number 3224A. I'll have to look at the parts list tomorrow to see how the steering arm itself is numbered.
8455
Post by 8455 »
The "bent" steering arm part number is ABI-3214-00.
I have attached a couple of comparison pictures.
Can you post a photo of the data plate?
8455
Post by 8455 »
Sure, here you go!
Took a couple pictures of the tire that is included in the assembly, and hopefully you'll be able to read the STC document.
8455
Post by 8455 »
A couple of the pics did not attach to the previous post. Here they are.
