O-290-D Exhaust
8359
Re: O-290-D Exhaust
Post by 8359 »
Well, the exhaust finally cracked. It's been welded over a few times and just keeps cracking in the same place. So I decided it was time to bite the bullet and get the cross-over system. I placed the order with Custom Aircraft today should hopefully be a week or so turn around time.
I'll keep you guys posted with the results!
8340
Re: O-290-D Exhaust
Post by 8340 »
Whew! Seeing that "weld" job someone had done makes me a little sick. When you first mentioned to me that an IA said your exhaust shouldn't be welded, just replaced, I though that's a silly concept. Now I see his reasoning. Yikes!
Joshua
8359
Re: O-290-D Exhaust
Post by 8359 »
Re: O-290-D Exhaust
8359 wrote: Wed Apr 10, 2019 12:08 pm First startup last night:
https://www.youtube.com/watch?v=ZZpmbXucMPQ
Very nice! Looks (and, sounds) great. ...curious -- do they recommend any tail pipe bracing (You may have some in place, but I didn't see it)? Thanks for sharing this journey as well as the obvious quality work by Custom. Mac
8359
Re: O-290-D Exhaust
Post by 8359 »
2066 wrote: Wed Apr 10, 2019 8:25 pm Very nice! Looks (and, sounds) great. ...curious -- do they recommend any tail pipe bracing (You may have some in place, but I didn't see it)? Thanks for sharing this journey as well as the obvious quality work by Custom. Mac
Thanks! I'm very happy with it! Yest the tail pipes are braced with rubber straps to the firewall. See below (I've since trimmed the pilot side duct).
ejohnny140
Re: O-290-D Exhaust
Post by ejohnny140 »
Where did you get your crossover system from? I’ve got the same setup and would like to go to the crossover. Thanks
