4004 wrote: ↑Sat Feb 02, 2019 3:53 am
It's not the color showing thru that's my concern. I just wasn't specific, etc. It's the "ridge line" caused by an extra layer when adding the vinyl oover the existing strip paint line. That was the suggestion to apply a test piece of vinyl overlapping the two elevations - bare then plus stripe and observing.
Hope this clears the issue - my apology for the confusion.
I follow you now! yea any scrap piece could test that..
8322 wrote: ↑Fri Feb 01, 2019 10:56 pmAnyone know how complicated and pricey it is to have a rudder rebalanced...
The only control surfaces that are balanced are the ailerons. The only time you have to balance the rudder is after you change the muffler bearings. <JK>
Good to know!
I like to change my muffler bearings at abojt same interval as the aileron fluid...
