Hot starting techniques
Re: Hot starting techniques
6643 wrote: Sun Jun 30, 2019 8:22 pm Since then I've never primed the engine unless I was cranking it over. No chance of an airbox fire, and always seems to work.
Good advice. Absolutely the safest method when using a primer.
6183 wrote: Mon Jul 01, 2019 6:59 am
Agree! And, yet another piece of good advice that's worth (much more than) the price of admission here!! Mac
7698
Aircraft Type: C120 - GAKVM
Post by 7698 »
2066 wrote: Mon Jul 01, 2019 7:39 am
Agreed... The best money I've ever spent. Great knowledge here.
7698
Post by 7698 »
Interesting in any thoughts about changing the air filter (Bracket type) for K&N and the effects on hot starting... Improvements or no change?
8452
Post by 8452 »
7698 wrote: Sun Jun 30, 2019 1:39 pm great ideas... Many thanks..
I'm never sure whether to prime or not...
I need to have a try and see what works best..
There should never be the need to prime (or choke) a hot engine.
Larry Bible
1966 Mooney M20F/J
Aircraft Type: Cessna 120
Post by 7896 »
Just a data point..........
It was over 90° F yesterday in Central Virginia. After flying for about 1 hour and making a brief shutdown/stop, I pulled the starter handle and the O-200 fired right up. No prime!
Cheers,
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
Post by 7950 »
For me, in the UK with C85 engine and Stromberg Carb ( G-BVUZ) with Pull starter. Cold start. Power on, mags on, throttle full closed.Prime ( 3 pumps) Pull starter. Any start up afterwards and on hot days. All off ( power fuel etc). Pull prop through 3 times by hand - clears any vapour lock I am told. NO prime. Throttle cracked open no more than 1/2". Power Mags on . Pull to start. This has worked for me last 3 years including the very hot ( for the UK) summer we had last year. If I don't do the pull through by hand thing then often she simply won't fire up.
