Big RPM drop with carb heat
Posted: Sat Feb 29, 2020 9:43 am
by mcidoug
At least the troubleshooting was straight forward. Time to replace the exhaust system...
Re: Big RPM drop with carb heat
Posted: Sat Feb 29, 2020 11:06 am
by 8342
Isn't the what the make duct tape for??
Posted: Sat Feb 29, 2020 9:40 pm
Time for the 150 exhaust upgrade!
Member's 150 Exhaust STC
Posted: Sun Mar 01, 2020 2:15 am
by 4004
No, Rick -you get the big kit of JB Weld.
Posted: Sun Mar 01, 2020 4:11 am
by 8474
Yes, but be prepared for a long wait from Wag-Aero. I ordered in November and still waiting....
Posted: Sun Mar 01, 2020 8:36 pm
by 8424
Hi mcidoug.
Not sure if this helps, but found these on Ebay.
https://www.ebay.com/itm/Lot-2pc-Cessna ... SwJ4peVGZu
21 hours to bid. 0 bids. minimum bid $199.
Steve A H
Posted: Mon Mar 02, 2020 2:43 am
by 8376
FA dodge can set you up with a great set..... and if you need the 150 support bracket I might be able to set you up with a guy that can produce one.
Posted: Mon Mar 16, 2020 7:45 pm
by 1125
I replaced my older 150 exhaust I purchased used in 1997 last year. Took it to Aerospace Welding in Eagan, MN for repair, they said it was toast. They put a new system together in 3 days, all components have part and serial numbers on them with the appropriate paperwork. I'm very happy with the installation and recommend them for all exhaust system needs. TO
Posted: Mon Mar 16, 2020 8:07 pm
by 8474
I might have to look for another option as Wag just told me today that now its end of March for mine......
Posted: Wed Mar 18, 2020 10:56 am
by 5806
Your photo is a great example of why the pancake mufflers have an inspection AD on them. Now if that had been the cabin heat side.....
