Approved Flight Manual
Posted: Sat Mar 28, 2020 5:54 pm
by gryph0n
Hello All,
The C 140 Type Certificate Data Sheet requires this piece of interior equipment:
403. CAA Approved Airplane Flight Manual (optional nomenclature:
"Approved Operating Limitations") and pertinent revisions applicable to the particular model and serial
number.
I was previously under the impression that the 120/140 Operations Manual fulfilled this requirement, but the Ops Manual makes reference to “the CAA Approved Airplane Flight Manual”, so it can’t be it.
Where does one find said Manual?
Thanks, Steve S
Re: Approved Flight Manual
Posted: Sat Mar 28, 2020 10:23 pm
by 2356
The original was a two page type written document that had specific data for each aircraft. Weight and balance, optional installed equipment. Hopefully it’s in your paperwork.
Posted: Sun Mar 29, 2020 8:52 am
It's Form ACA-309. It should be in your permanent aircraft records. If not, order the FAA CD for your plane. It should be in there. I'm attaching mine, so you can see what it looks like.
I'm guessing there is a large percentage of the fleet that is not carrying this document... Mine's not up to date: I have a C90 now.
Posted: Sun Mar 29, 2020 9:58 am
by gryph0n
Helpful, thanks John and George.
Posted: Sun Mar 29, 2020 11:39 am
by 6277
Here's what I thought
- AFM.pdf
- (329.38 KiB) Downloaded 1026 times
was the Approved Flight Manual.
Posted: Mon Mar 30, 2020 7:33 am
by 8233
6277 wrote: ↑Sun Mar 29, 2020 11:39 am
Here's what I thoughtAFM.pdf was the Approved Flight Manual.
Ray,
I believe you are correct. See attached Service Letter from the library that states CAA Form 309 is no longer needed in favor of what you posted.
Posted: Mon Mar 30, 2020 8:18 am
by 8474
Is there one of these available for the A model?
Posted: Tue Apr 07, 2020 10:31 pm
by regular122
Is there one for a 140 with a Continental 90?
Steve
Posted: Wed Apr 08, 2020 2:52 pm
regular122 wrote: ↑Tue Apr 07, 2020 10:31 pm
Mine is for a C85 with a few things crossed out and the correct values penciled in.
Posted: Thu Apr 09, 2020 10:46 am
by 6183
8474 wrote: ↑Mon Mar 30, 2020 8:18 am
Yes, do you have a copy of the Association Maintenance Manual? There's a copy in that book that can be used.
