C85 Magneto choice
Posted: Thu Apr 30, 2020 9:33 am
by 7698
Having had my right Eisemann magneto fail for the second time I'm just about to purchase a set of replacement items...
Ive looked at the Slick upgrade kit K4520-40, but also considered buying refurbished Bendix 10-500514-1R...
With no experience of either Im looking for some guidance... One overhaul shop in UK suggested Bendix over Slick, so interested in experieinced thoughts.
Re: C85 Magneto choice
Posted: Thu Apr 30, 2020 10:37 pm
by 6298
I have used, and liked, the Slicks for years. The Bendix are very good, too. Eisemann are pretty much obsolete!
Posted: Fri May 01, 2020 7:18 am
Either Slick or Bendix will do the job. The price on the Slicks used to be a factor, but now I think there's not much difference between the two. The Slicks have more throw-away parts but the parts tend to be cheaper, so it's really a wash there, too.
Posted: Fri May 01, 2020 9:58 am
by 7698
Thanks guys, useful information.
Posted: Fri May 01, 2020 12:51 pm
IIRC, you'll need new/serviceable gears for the update... Just something to factor in the budget.
Posted: Fri May 01, 2020 1:47 pm
by 7698
2066 wrote: ↑Fri May 01, 2020 12:51 pm
Good point... Luckily, having only recently carried out a major overhaul on the bottom end I've had the gears inspected and NDTd and all good. Should probably replaced the Eisemanns at the same time..
Posted: Fri May 01, 2020 2:34 pm
7698 wrote: ↑Fri May 01, 2020 1:47 pm
That's great...we are talking about the mag drive gears that are attached to the mags. Best I recall the gears on the Eisemanns will not fit on the new mags(?).
Mac
Posted: Fri May 01, 2020 4:02 pm
by 7698
2066 wrote: ↑Fri May 01, 2020 2:34 pm
Mac
Understand.. I was referring to the mag gears... Part no 36067. They look to be the same fitting style for Slick Impulse?
Posted: Fri May 01, 2020 5:22 pm
by 7981
Just swapped out my Eisemann's for TCM with harness. Slick's are OK. I have always had better service from TCM/Bendix. Don't forget spark plugs and "P" lead inspection to finish out the installation.
Posted: Fri May 01, 2020 5:42 pm
7698 wrote: ↑Fri May 01, 2020 4:02 pm
Mac
Hope so. We recently changed out the Eisemanns on Tom Reddeck's 140 (C85) and the drive gears had to be changed, too, as the Eisemanns would not fit. Maybe yours are a different model.
Mac
