Cable tension
Posted: Sun May 17, 2020 6:53 pm
Hi folks, I need some insight / advice.
I had to remove a wing and am putting it back on and trying to get the cable tension correct. The only reference found is the Operation Manual that provides a spec of "approximately 30 pounds". What's a reasonable plus and minus? Also, on the bellcrank the control cable is 1" closer to the pivot than the carry-through cable. I don't think you can get both cables the same tension. so which cable do you measure? I'm leaning toward getting the control cables as close to 30# as I can and not worrying about the carry through other than to make sure it's not way too tight or loose. Since there's no pulleys on the carry-through cable, i don't think I have to worry about too much load on a pulley (too tight) or so loose that it jumps off a pulley.
What have others done?
Dave
Dave
