Sky Tec starter problems
Posted: Wed May 20, 2020 1:47 pm
by cubrath
I have the sky tec C12ST2 starter on my 140. It had an oil leak which was dripping on the alternator. We took it off and opened it up. It was full of engine oil. Left a message with Sky-tec but no response yet. Worked great but I’m guessing it will need to be replaced. Go back with the sky tec or are there other options you guys would recommend??
Re: Sky Tec starter problems
Posted: Wed May 20, 2020 2:29 pm
by 4004
I don't know anything about Skytec except have heard some "negatives" over the earlier years with ones on the big bore Continentals which had a unique starter system. However, one would think that the shaft seal could be replaced? If you need to replace, suggest you get a B&C starter. He's been in the business for years with products that he has developed/designed himself and I have worked with them on a field approval and very cooperative.
Not meaning to imply his starter requires a field approval, it is approved. I have one on an 0-200.
Posted: Wed May 20, 2020 3:20 pm
We installed the Sky-Tec @ overhaul a few years back. There was a "failure" that may have been caused by the pinion not having been cut off quite enough. That said (and, admitted), Sky-Tec had a new starter on my front porch the next day -- their expense totally. We "trimmed" the pinion a bit more and the new starter has performed flawlessly...as one of our members has said in jest -- "if there's an engine failure, I can get home on the starter!". Now, since Sky-Tec has been sold to a larger organization and Rich Chiappe (One of the original Sky-Tec developers/owners) is no longer involved, I don't know about current service responsiveness and quality, but I remain a fan of the "old" company's customer focus. (I have a "mix" on our 140...Sky-Tec starter and a B & C alternator. They seem to coexist with little conflict, FWIW. Excellent quality IMO, both. :) ). Mac
Posted: Wed May 20, 2020 8:48 pm
by cubrath
Just an update. Talked to the factory today and the version I have is 18 years old. There have been many updates over the years and no overhaul available on this model. Looks like a new one is in my future. Not sure if I’ll stick with SkyTec or go with B&C?? I’ll do a little research tomorrow. Do like the smaller companies!
Posted: Thu May 21, 2020 7:31 am
by 6183
2066 wrote: ↑Wed May 20, 2020 3:20 pm We installed the Sky-Tec @ overhaul a few years back. There was a "failure" that may have been caused by the pinion not having been cut off quite enough. That said (and, admitted), Sky-Tec had a new starter on my front porch the next day -- their expense totally. We "trimmed" the pinion a bit more and the new starter has performed flawlessly...as one of our members has said in jest -- "if there's an engine failure, I can get home on the starter!". Now, since Sky-Tec has been sold to a larger organization and Rich Chiappe (One of the original Sky-Tec developers/owners) is no longer involved, I don't know about current service responsiveness and quality, but I remain a fan of the "old" company's customer focus. (I have a "mix" on our 140...Sky-Tec starter and a B & C alternator. They seem to coexist with little conflict, FWIW. Excellent quality IMO, both. :) ). Mac
Had a similar issue (oil leak) and Sky-Tec replaced the unit for me also. I personally like the company's product over the original Delco Remy starter, and I'm one of those that agrees that I think you could fly the airplane home on that starter unit alone, it sure spins the engine faster than the OE unit did. Same here on the current service responsiveness, I don't know; however, I wouldn't hesitate to use the Sky-Tec unit or B & C starter. I think they're much better than the original starter:) Mike
Posted: Fri May 22, 2020 8:37 pm
by steve140
I've had a B&C starter for about 15 years. No problems at all.
