I need some help! I am in the process of restoring a 1947 140 that I bought as a project. The plane was completely disassembled when I took possession. I have access to the illustrated parts book here on the forum but there is insufficient detail to figure out the routing of the control cables. Is there such a thing as an assembly book for the plane or can someone take a picture of the cables and how they pass through, over, around, or under the gear box? I suspect I will need help when I attempt to rig the trim cables also. Thanks!
Steve Hawley
Rudder cable routing
8224
- Name: Blaine F
- Aircraft Type: C140A
Re: Rudder cable routing
Hi Steve,
Have you invested in one of these: https://cessna120140.com/product/techni ... ce-manual/
For a project like yours I would think it would be a good investment.
