Scott Brake Cylinder
Posted: Fri Nov 20, 2020 8:29 pm
by 8209
Does anybody know where I could get the o rings and u cup to rebuild my Scott brake master cylinder?
Brent
Re: Scott Brake Cylinder
Posted: Wed Dec 23, 2020 8:43 pm
by 4751
Univair.
Posted: Wed Dec 23, 2020 10:09 pm
If your cylinder is original equipment, searching "brake master cylinder" may help zero in on what's needed, then Univair or Spruce or others can supply. In looking back a bit there's this related post by one of our Moderators: "AN6227-7 or MS28775-012 (o-ring). The cylinder is a very simple design and the o-ring is the only wear part. There is a little pin that cocks the o-ring at the top of the stroke to allow fluid in and out of the reservoir. The o-ring takes a set .." Hope that'll help. Mac
Posted: Thu Dec 31, 2020 9:15 pm
by 8209
Thanks for the info guys.
Posted: Fri Jan 01, 2021 7:46 am
The original master cylinders are Goodyear, not Scott.
