Steps
Posted: Fri Nov 20, 2020 10:27 pm
When I got out of the plane the other day the Step gave way! That was exciting. The failure was along the intersection of the weld and the bent steel piece and ran from the bottom of the assembly at the crest of the bend up around the top of the step and into the large hole in on the bottom of the gear leg. I suppose that is right where all the tension is when someone steps on the step.
I find surprisingly little on the forum, webpage, and internet in general on this. No good source that I can find for replacements except junkyards which I find a little surprising
I saw a 140 getting annualed today in Liberal, KS and both of its steps are starting to crack along the top of the welds. We must not be the only ones!
Any suggestions from the brain trust?
