molded grease seal for wheel assembly
Posted: Sun Jan 31, 2021 6:03 pm
Hi All. When looking at ACS to buy some new felt grease seals I realized I had the wrong bits in my wheels. Instead of a Ring-Grease Seal (illustration #9A) and a cupped ring seal (#10 - but no longer available), I had two Ring-Grease Seals (maybe because #10 is NLA). Rather than buying / finding the missing bits I decided to upgrade to the Molded Grease Seal as it should seal better and didn't require the missing parts. The inner wheel half went together without problem not so on the outer half. If I add the Molded Seal and the Ring Grease Seal (#9A), the stack is too tall and I can't see, let alone fit, the snap ring (#14). In addition, when trial fitting the wheel to the axle (sans snap ring), the assembly is too thick to allow me to insert the cotter pin through the castellated nut. The bearing races are seated properly into the wheel halves.
I'm tempted to go back to the felt seals - and throw away $130 in molded seals. Has anyone upgraded to the molded seal? Did you have these issues too?
Taking suggestion......
Dave
Dave
