wing spar repair?
Posted: Fri Feb 05, 2021 10:35 am
by 4280
I recently bought a 1946 Cessna 140 which had been propped and got away and ran into a fence row. Damage is pretty much limited to the left wing tip and right elevator, It may be one of the lowest time 140's in the country...630 TT !! And, yes that is true. In fact the mate to it is here close by with 650 hrs. They were bought at the factory and flown to Knoxville, TN on the 16th of November 1946. But, I digress. The damage to the left wing is between the landing light and the wing tip bow. Both are intact ! However, the front strut is bent backward about the last 12" at maybe a 20-30 degree bend. Is there a repair possible or does the front spar or wing have to be replaced ? Thanks you for any help. Oh, who is the guru who can answer that question for me ?
Re: wing spar repair?
Posted: Fri Feb 05, 2021 11:53 am
You can use AC43-13.1b as a structural repair manual.
When you say "the front strut is bent backward about the last 12" at maybe a 20-30 degree bend," do you mean the lift strut? That's going to be tough to repair without a jig, but there are repair methods for streamline tubing in the same AC. You can get a new one from Univair, but the rear strut won't match the other side. However, they have the jig, so, may be able to fix yours.
Posted: Fri Feb 05, 2021 12:40 pm
by 4280
I'm sorry...I miss-spoke when I switched from spar to strut.It is the front SPAR !
Posted: Fri Feb 05, 2021 3:30 pm
Is that the only thing that is bent? Any pictures?
Posted: Fri Feb 05, 2021 8:46 pm
Depends on what your sheet metal expertise is. I had a somewhat similar situation, I replaced the wing.
Is the wing metalized or fabric?
Posted: Sat Feb 06, 2021 8:19 am
by 4280
It's fabric wing. Everything from The Landing light to the wing tip bow is pretty much destroyed the rear spar is not damaged and the front spar has that been. I may be able to post a picture
Posted: Sat Feb 06, 2021 8:42 am
Moving this to the Tech Discussion forum.
Posted: Sat Feb 06, 2021 11:49 am
by 4280
The bend on the front Spar is midway between the last two lightning holes in The Spar. It is bent at station 72.125
Posted: Sat Feb 06, 2021 11:52 am
by 4280
I have the aircraft inspection, repair and alteration manual with a c 43.13 - 1B and 2B but so far I haven't found much help as far as splicing or reinforcing and aluminum spar
Posted: Sat Feb 06, 2021 2:23 pm
Repairing the spar is a major repair. If the exact repair isn't covered in 43.13 (look in Par 4-58) then you either need data from Cessna or you need to replace the spar.
