Best Door seals
Posted: Tue Mar 30, 2021 8:01 am
by 8466
I need to replace my door seals. What is the best on the market for that application ? Cement? Also I need to replace my head liner. Any reasonable cost alternative for a headliner? Material? Soundproofing? Cement or or other mounting options?
thayne Inman
Re: Best Door seals
Posted: Tue Mar 30, 2021 8:53 am
by 8474
Airtex is your source for the headliner, they have been making interiors for the 120/140 since the 1940's. They can supply you with the glue as well. Be aware though, that this is not an easy undertaking, the skylights are a real challenge to get right. I would recommend buying Lorraine Morris's DVD.
I might get a ribbing over this but I bought some door seal on Amazon for $5 thinking there was no way it could be any good, but actually I was surprised. Probably not going to last, but it has sealed the door nicely so far.
https://www.amazon.ca/gp/product/B08CS9 ... UTF8&psc=1
Re: Best Door seals
Posted: Tue Mar 30, 2021 6:19 pm
by a64pilot
8474 wrote: ↑Tue Mar 30, 2021 8:53 am Airtex is your source for the headliner, they have been making interiors for the 120/140 since the 1940's. They can supply you with the glue as well. Be aware though, that this is not an easy undertaking, the skylights are a real challenge to get right. I would recommend buying Lorraine Morris's DVD.
I used the same seal in white, pulled it in half though and it works well for my windows also. This is at least enough to do two aircraft
https://www.amazon.com/gp/product/B07DD ... UTF8&psc=1
Re: Best Door seals
Posted: Tue Mar 30, 2021 7:52 pm
Bill Rhodes up in Minnesota used to have the "real McCoy" door seal if you want to go that route, you could contact him, he probably still has more.
Re: Best Door seals
Posted: Tue Mar 30, 2021 8:48 pm
by 8474
I contacted Bill and he doesn't have any left unfortunately.....
Re: Best Door seals
Posted: Wed Mar 31, 2021 7:33 am
