Fuel gage torque value
Posted: Sun May 23, 2021 5:56 pm
by 6468
Installing new gaskets on my fuel gages. Looking for the recommended torque for the four 1/4-28 screws. I'm certain it's a much lower torque than standard torque used in tension, Only want to correctly crush the gaskets & not over torque (and crack the gage housing), Does anyone out there know the recommended torque? Thanks, Jim S
Re: Fuel gage torque value
Posted: Mon May 24, 2021 9:08 am
by 6898
I find every now and then it's hard to find a torque for every application. I'm sure someone will chime in with info. If its a cork gasket it does not take much . Cork is soft and I could see bending or cracking the tab. I use a thin smear of Hylomar sealant on both sides and a good solid turn of the screw should do.
Posted: Mon May 24, 2021 11:32 pm
by 8233
6468 wrote: ↑Sun May 23, 2021 5:56 pm Installing new gaskets on my fuel gages. Looking for the recommended torque for the four 1/4-28 screws. I'm certain it's a much lower torque than standard torque used in tension, Only want to correctly crush the gaskets & not over torque (and crack the gage housing), Does anyone out there know the recommended torque? Thanks, Jim S
Older gauges, don't exceed 20 in-lbs of torque. Newer Rochester gauges 20-50 lbs of torque is acceptable. Over 20 will crack an older gauge. Ask me how I know. :D
Posted: Tue May 25, 2021 5:33 am
by 8342
[/quote]
Older gauges, don't exceed 20 lbs of torque. Newer Rochester gauges 20-50 lbs of torque is acceptable. Over 20 will crack an older gauge. Ask me how I know. :D
[/quote]
Inch pounds or foot pounds? It is a bit of a difference.
I know but others may not.
Please be caerfull of what you say.
Posted: Wed May 26, 2021 11:47 pm
by 8233
Inch
(corrected)
