UAVIONIX Wing tip ADS-B
Posted: Sun Jun 13, 2021 1:13 pm
by sunshinelawyer
Has anyone installed an UAVIONIX Wing tip ADS-B?
I know at least one person has the tail version but was considering the wing tip version for the strobe.
Re: UAVIONIX Wing tip ADS-B
Posted: Sun Jun 13, 2021 4:21 pm
by a64pilot
I have the tail version, on some aircraft it may be prudent if installing the tail version to rebalance the rudder, but I don’t think ours is balanced
I don’t believe there is any significant difference between the tail and wing tip. the wingtip is slightly cheaper for some reason.
And for some reason it’s apparently a major alteration as it requires a 337, the paperwork takes longer than the install, not much could be easier
Posted: Mon Jun 14, 2021 7:15 am
by sunshinelawyer
Posted: Mon Jun 14, 2021 11:29 am
by 6478
I haven't seen any on 120/140 wingtips, but I have a friend with a 150 who had one. Worked fine, but after he banged his head into the antenna fin a couple of times he sold it and bought a Tail Beacon instead. I'm sure people get used to it eventually but it's something to consider. Too bad they don't make a "top antenna" version for high-wing aircraft.
Posted: Mon Jun 14, 2021 12:34 pm
by 6843
On a point somewhat related to the original post. I was recently told the following, I THINK it's accurate but plan on researching further before I buy.
What kind of flying do you do and where? The Skybeacon is a 978 beacon. As such, it is a ground based system. The Tailbeacon X is a 1090 beacon and satellite based. The big difference for me is the ground based system doesn't see you if you're playing down low or behind mountains. I have a 122.5 ELT. I hoped ADSB would substitute for buying a new ELT and satisfy my safety solution of being found if I go down. A 978 beacon won't help with that.
I plan on researching more at OSH this year.
Posted: Mon Jun 14, 2021 6:11 pm
by a64pilot
The tailbeacon-X is a whole different animal, it’s also a transponder and of course need one of a couple different devices inside the aircraft to tune the transponder. I came close to getting one for my Mooney and putting the tailbeacon in the Cessna, however I couldn’t find out how much hassle it is to change squawks, current transponder if I’m told squeak 1611, I just push buttons 1611, the tailbeacon is going to require more steps, how many I haven’t any idea, but I believe the device only has two buttons, maybe three
Then $$$ reality set in, it’s a great price for what your getting, but still inst cheap.
Most likely it will be paired with an AV-30, but an AV-20 will work, with the -30 bundle you save $300, but it’s still over $4,000
For safety a 243.0 ELT or a PLB would be better in my opinion. ADSB first someone has to be paying attention and they may think you just landed in a grass strip
https://uavionix.com/product/tailbeacon ... -c-bundle/
Oh, maybe the tailbeacon-X is both a 978 and a 1090, so if your going to Europe or class A airspace your covered, neither is likely for me.
Posted: Tue Jun 15, 2021 7:27 pm
a64pilot wrote: ↑Mon Jun 14, 2021 6:11 pm I couldn’t find out how much hassle it is to change squawks, current transponder if I’m told squeak 1611, I just push buttons 1611, the tailbeacon is going to require more steps, how many I haven’t any idea, but I believe the device only has two buttons, maybe three
Buttons? It's configured by an ap on your phone.
As far as changing squawks, the tailbeacon listens to your transpoder and copies it. Easy-peasy. (That's the secret sauce!)
Posted: Tue Jun 15, 2021 8:58 pm
by 8014
My A&P/I said he'd put either in our 120 but he recommended the tail beacon because it was usually easier to install. We've had it since 10/2019 and have not had any problems. It also did not seem to affect the trim or rudder balance. Plus, you can't whack your head on it if you're over 4' tall.
Posted: Wed Jun 16, 2021 10:50 am
by a64pilot
6643 wrote: ↑Tue Jun 15, 2021 7:27 pm
Not the tailbeacon-X, it IS the transponder, you no longer have a transponder in the panel, and I assume no longer have a blind encoder either.
Makes one wonder how IFR certs will be done now.
But anyway as the -X is the transponder, it requires a control head to control it, hence the need for either the AV-20 or -30
Here is a link to the -X
https://uavionix.com/products/tailbeaconx/
I was responding to 6843
Posted: Wed Jun 16, 2021 7:00 pm
by 8474
a64pilot wrote: ↑Mon Jun 14, 2021 6:11 pm The tailbeacon-X is a whole different animal, it’s also a transponder and of course need one of a couple different devices inside the aircraft to tune the transponder. I came close to getting one for my Mooney and putting the tailbeacon in the Cessna, however I couldn’t find out how much hassle it is to change squawks, current transponder if I’m told squeak 1611, I just push buttons 1611, the tailbeacon is going to require more steps, how many I haven’t any idea, but I believe the device only has two buttons, maybe three
Canada also will require 1090 when that mandate becomes effective....
