C140 Flap Lever Assembly
Posted: Thu Jul 01, 2021 9:35 pm
by stephendriskell
I’m looking for figure 15 reference 44 part# 0411322. It houses the detent that the flap lever uses to hold the flaps in position when deployed.
Mine has completely worn out and is in need of replacement. So I’m looking to find and purchase, long shot, or manufacture one using the old part as reference.
Looking for advice for either. Here is pic of worn out part.
Re: C140 Flap Lever Assembly
Posted: Fri Jul 02, 2021 6:40 pm
by 8424
Hi Stephen, This is Stephen who goes by Steve A H on this forum!
In my parts manual your part is 15-33...part number 0411322, Cover Assembly - Flap Control - Left - (Serial 8001 - 10069)
Here's you long shot!
I have one, and will send you a PM.
Steve A H
Posted: Sun Jul 11, 2021 5:35 pm
by 8424
Stephen,
Did you locate an assembly?
Mine is still available. Let me know if you need it.
Steve A H
Posted: Wed Sep 08, 2021 10:49 am
by atypicalguy
Not sure how this turned out but I could use that part if it is for the twist grip handle.
Karl
Posted: Thu Sep 09, 2021 7:26 pm
by 8424
Hi Carl!
The gentleman looking for this part never responded to the above post or to PM's that I sent him, so it is available to you if you are interested.
I also have the right side of the assembly, shown below (figure 15-12 0411323, cover assembly - flap control - right) , but it has a latch assembly attached at the front for what appears to be the push button lever operation. It appears a part has been removed from the holes in the lower front of the piece.
These parts are in the exploded view of the twist handle unit in the parts manual, but I have no experience with this type of flap handle. Just happened to get these in a box full of parts I purchased a while ago.
I've sent you a PM.
Steve A H
Flap control assembly right 1a.JPG (24.43 KiB) Viewed 3731 times
[attachment=0]Flap Control Assembly Right 2a.JPG[/attachment
