rudder travel stops?
Posted: Sun Aug 15, 2021 11:12 pm
by 8475
The operating handbook says to set rudder travel limits by shimming the stops on the aft bulkhead. I can't find these. Can anyone tell me where these are located? Post a pic?
Thanks in advance.
Re: rudder travel stops?
Posted: Mon Aug 16, 2021 11:11 am
by 2356
There should be two AN3 bolts on either side of the tail bulkhead. Add washers under the bolts till you get the proper travel.
Posted: Mon Aug 16, 2021 11:13 am
Here y'are (Yikes! Please overlook the grease & grime! :roll: ):
Posted: Mon Aug 16, 2021 7:11 pm
by 8475
Ah, yes. Thank you. Not at my plane right now, but I believe that those are 2 of the 6 fasteners that also secure the vertical fin spar to the rear-most bulkhead of the fuse. Thanks so much.
Posted: Tue Aug 17, 2021 10:13 am
Can anyone find these screws in the parts catalog? (I can't...)
I suspect they should be special stop screws, not standard AN bolts. The differences are, full length threading and no raised markings on the head.
Posted: Tue Aug 17, 2021 1:24 pm
6643 wrote: ↑Tue Aug 17, 2021 10:13 am Can anyone find these screws in the parts catalog? (I can't...)
IDK. The four I've looked at have AN bolts. The ref. manual (simply) reads: "...bolts which serve as stops". The parts catalogue (pg. 45, figure 23) shows and refers to an "AN3H-6A" if I'm reading correctly & which would have a drilled head(?). Again, all I'm seeing is a "standard" AN3 bolt (without a drilled head). ...interesting.
Posted: Tue Aug 17, 2021 3:41 pm
Ah ha! There they are, in with the tail spring. Yeah, what's the point of the drilled head?
Posted: Wed Aug 18, 2021 5:37 am
by 8424
The 140A parts manual shows an AN3-6A. figure 22, page 38 reference number 43, (Bolt - Adjust Rudder Travel)
Guess they figured out they didn't need the hole the head!
Steve A H
Posted: Wed Aug 18, 2021 11:02 am
Steve A H wrote: "Guess they figured out they didn't need the hole the head!"
:D . Yep. ...can't help but picture some diligent technician trying to figure out where to connect the "other end" of the safety wire...from the drilled "hole in the head" to...?. :?
Posted: Thu Aug 19, 2021 8:10 am
"Looks like we're out of AN3-6A bolts. Are we still using these AN3H bolts for anything?"
