propeller pitch
Posted: Mon Oct 25, 2021 7:52 am
by thing73
I have a macauley prop 71/48 and know this is considered a cruise prop.... I know a climb prop would be less than 48... what is a reasonably pitch for a climb prop???
Re: propeller pitch
Posted: Mon Oct 25, 2021 9:23 am
by 6183
Re: propeller pitch
Posted: Mon Oct 25, 2021 10:19 am
thing73 wrote: Mon Oct 25, 2021 7:52 am I have a macauley prop 71/48 and know this is considered a cruise prop....
7148 is considered a "normal" prop for the C85. 7146 would be a climb prop. To optimize climb, find the pitch that gives you the maximum allowed static RPM.
Re: propeller pitch
Posted: Mon Oct 25, 2021 10:25 am
Interesting... It looks like Textron has reinstated the "Avoid continuous operation between 1950 and 2170 rpm" limitation!
Re: propeller pitch
Posted: Tue Oct 26, 2021 9:03 am
by 6339
6643 wrote: Mon Oct 25, 2021 10:25 am
If you select the C-90 engine it doesn’t have the restriction.
Re: propeller pitch
Posted: Tue Oct 26, 2021 10:28 am
6339 wrote: Tue Oct 26, 2021 9:03 am If you select the C-90 engine it doesn’t have the restriction.
It never did. McCauley rescinded the restriction in a service bulletin in 1949. I think Textron has just republished obsolete information.
Re: propeller pitch
Posted: Fri Oct 29, 2021 7:36 am
by cdoughty
I asked McC this question and the response was "where did you see this??. The TCDS has no restriction and there is no restriction". I responded "heard it on your website" and haven't gotten a response yet. So John is right, unless you want to trust the web-master over tech support.
Re: propeller pitch
Posted: Sat Oct 30, 2021 6:18 am
Re: propeller pitch
Posted: Sat Oct 30, 2021 6:36 pm
by 8342
Thank you John for posting a definitive answer to the placard question.
