Seat frame holes
Posted: Wed Dec 08, 2021 6:03 pm
by 8342
My airplane originally came with the seat cushions and I want to switch to the seats that use a frame.
Airplanes with serial number 11842 and below used a cushion and after that they used a frame.
I need to know the location of the holes that the frames go into.
Thanks in advance,
Re: Seat frame holes
Posted: Thu Dec 09, 2021 1:51 pm
I believe that there's a difference in the floor pans, so it may be that the framed seats won't be a drop in, even with the holes drilled(?). If no one wades in with definitive info. I may be able to provide pics of both in a few days (...kinda cold in mine and my neighboring 140 owner's hangar today ;) ). Mac
Posted: Thu Dec 09, 2021 4:20 pm
2066 wrote: ↑Thu Dec 09, 2021 1:51 pm I believe that there's a difference in the floor pans, so it may be that the framed seats won't be a drop in,
That's my recollection, too, but I bet David Lowe knows the answer. Might be a good idea to give him a call. I know the contour of the floor is important, because if you swap the seats left for right, they won't fit correctly.
Posted: Fri Dec 10, 2021 1:54 am
by 4004
Why not get the frames and then drill holes to fit? Macs pictures should give you the pan,etc layout to see what frames you'll need. My serial # is 13913 with the frame seats. I can give measurements to compare with Macs - just too old to do pics, etc, however, if "back is to wall", I can do digital pics and get family to send or run hard copies and mail.
Edd
Posted: Fri Dec 10, 2021 6:25 am
by 8342
2066 wrote: ↑Thu Dec 09, 2021 1:51 pm I believe that there's a difference in the floor pans, so it may be that the framed seats won't be a drop in, even with the holes drilled(?). If no one wades in with definitive info. I may be able to provide pics of both in a few days (...kinda cold in mine and my neighboring 140 owner's hangar today ;) ). Mac
The IPC shows that from serial number 10070 and higher all used the same seat pan. Figure 15.
The seat frame usage started from serial number 11843. Figure 41.
I have serial number 11245. So my pan should be correct. I just need to know where to put the holes.
I think I know where they go, but would like to know for sure.
Posted: Fri Dec 10, 2021 8:42 am
8342 wrote: ↑Fri Dec 10, 2021 6:25 am The seat frame usage started from serial number 11843. Figure 41.
Interesting. I have sn 10503 and I have the later seats, with holes. If I get to the airport before someone posts the answer, I'll locate the holes for you.
Note that the seats for the 120 are different. I think they always had cushions with no frames.
Posted: Fri Dec 10, 2021 10:55 am
John wrote: "Interesting. I have sn 10503 and I have the later seats, with holes."
It is (getting even more) interesting. I have SN 9351 and have the later seats. As David and Victor remind us from time to time, a "few" parts and pieces have been changed out over the years(?). (FWIW, and may or may not be related, I also have the "Angle Support" #0411502 L & R in my gear support area.) (In my mind's ear, I'm hearing Johnny Cash singing "One Piece at a Time" ;) ). Will try to get pics today...just don't find those rountoits as fast as I used to :| .Mac
Posted: Fri Dec 10, 2021 11:40 am
2066 wrote: ↑Fri Dec 10, 2021 10:55 am John wrote: "Interesting. I have sn 10503 and I have the later seats, with holes." and "Note that the seats for the 120 are different. I think they always had cushions with no frames."
It is (getting even more) interesting. I have SN 9351 and have the later seats. Joe Mancusi's '47 120 had the later seats, but "converted" to 150 seats -- I borrowed his old take-outs while mine were being reupholstered. As David and Victor remind us from time to time, a "few" parts and pieces have been changed out over the years(?). (FWIW, and may or may not be related, I also have the "Angle Support" #0411502 L & R in my gear support area.) (In my mind's ear, I'm hearing Johnny Cash singing "One Piece at a Time" ;) ). Will try to get pics today...just don't find those rountoits as fast as I used to :| . Mac
Posted: Sat Dec 11, 2021 9:26 pm
RIGHT SIDE
RIGHT SIDE
CENTER
CENTER
LEFT SIDE
LEFT SIDE
Hopefully these will help a bit? If you need more, or if you need measurements...let me know. I haven't got that 'rountoit to compare floor pans with neighbor's 140, but will do ASAP & report. Hope this'll help. Mac
Posted: Sun Dec 12, 2021 7:52 am
by 8342
Thanks Mac.
That should do it.
