starter arm tension spring
Posted: Sun Jul 08, 2018 9:23 pm
The pull type starters have a built in spring to push the gear plunger back out away from the flywheel gear. My 140 (85hp) has a spring attached to the arm that is pulled to actuate the push button on the starter. A friends 85 hp does not have the spring attached to the arm. What gives? And if the "helper spring" on the arm is necessary, anyone have an idea as to its dimensions, etc?
