Engine Swap Question
Posted: Mon Feb 21, 2022 11:22 pm
by simonlowther
Is a change from a C-85 to C-90 just a straight change, or is there more to it?
Si
Re: Engine Swap Question
Posted: Tue Feb 22, 2022 1:20 pm
It's pretty straight forward. The exact requirements are spelled out in Note 5 of aircraft specification A-768. You'll likely need to repitch your prop, unless you currently have a cruise prop.
Posted: Tue Feb 22, 2022 4:37 pm
by simonlowther
Thank you
Si
Posted: Tue Feb 22, 2022 6:00 pm
by 6298
If the C-90 is a -14 or -16 the same mount will work. If it’s a C-90-14 you will need a different mount.
Posted: Wed Feb 23, 2022 1:50 am
by 4004
Randy, check your response - C-90-14 will or won't require different mount? There's always one smart XXX in the crowd!
Posted: Wed Feb 23, 2022 9:56 am
I think that's a typo and he meant "-12 or -16."
