Grove axles upgrade
Posted: Thu Mar 31, 2022 3:30 pm
Hello all.
Thanks for any help in advance. I did read previous post on the subject and became confused regarding the necessary paperwork to do this correctly.
My 120, SN9734 has all four 5/16th bolts, and has extensions as well.. I want to replace with the solid Grove Axles and remove the extensions. They said they do offer the axles with all four bolt holes 5/16th. (no need to drill) They also offer AN hardware kits, instead of using MS sheer bolts??? (not sure I like that).
I spoke with them today, they said they do not offer an STC. They said this is done via field approval. They did have some examples of the 337's used for field approvals in the past.
Any suggestions on the proper bolts to use and field approval process?
Mark
Mark
